raluca_edu
You can find extension here: https://marketplace.ptc.com/apps/193524/java-sdk#!overview
Or from support portal (see attached image).
Hope it helps,
Raluca Edu
raluca_edu
Hope it helps,
Raluca Edu
Thanks for the reply. How can we identify Thingworx 8.5 equivalent java SDK or other versions?
Sathishkumar C.
raluca_edu
Usually, the latest version found on Support Portal is compatible with Thingworx 8.5.
Hope it helps,
Raluca Edu
