How to dynamic load thing?
Hello. every body.
I have a question.
I am doing mashup design.
First. Entry Picker widget.
Second. Button widget
Third. DynamicThings thing.
Fourth. Grid widget
Fifth. QueryPropertyHistory Action.
and then I want show Data from selected entry picker.
But I can't see result.
I want to see the results from dynamically things.
Could you help me.
Get service results from Dynamic Thing, you should use ThingTemplate as data source, and Enable Dynamic selection.
jaiminLee1-VisitorAuthor
Thank you.
But My problem is not solved.
I can mashup design (Thing+ grid+ querypropertyhistory).
But I can't make [Ting list (dynamic select from entry picker) + girid + querypropertyhistory)]
Then you need to customize a service, Thingname is the service input that receives the entity name.
// result: INFOTABLE dataShape: ""
var result = Things["Thingname"].QueryPropertyHistory({
oldestFirst: undefined /* BOOLEAN */,
maxItems: undefined /* NUMBER */,
endDate: undefined /* DATETIME */,
query: undefined /* QUERY */,
startDate: undefined /* DATETIME */
