6-Contributor
How to embed the mashup directly from the front-end, bypassing the login info without exposing key
Hi everyone
    My application scenario is that the mashup application is directly accessed through the micro application, and there is no user login during this process. How do I need to achieve this?
Requirements: The access connection cannot expose Appkey and user information.
Do I need to use Authenticator to realize the function?
Has anyone implemented it or has a similar case there?
Please let me know if you know
Thank you so much and have a great life
@YF_9574894 ,
If you want a scenario where a user does not have to log in to ThingWorx or expose an application key, I would suggest using Single Sign-on if that is something that your team uses.  If you do not use SSO, you may need to craft some custom Authenticator to meet your specific need.
- Nick
