How to enable/disable Full Screen(F11) mode by clicking a Button?
Hi There,
I was trying to enable full-screen mode by clicking a button instead of f11 option.
I used the following HTML code as a normal HTML file, works cool.
<button  onclick='document.documentElement.webkitRequestFullscreen();'>Go Fullscreen Mode</button><button onclick='document.webkitExitFullscreen();'>Close Fullscreen</button>
I also tried HtmlTextArea widget with the read-only option enabled, Not getting the expected result.
Even I tried WebFrame widget to call the HTML file and execute, not worked.
Give me a solution if exist.
Add an Expression widget and on the expression field set:
($("#runtime")[0].webkitRequestFullScreen()?$("#runtime")[0].webkitRequestFullScreen():($("#runtime")[0].mozRequestFullScreen()?$("#runtime")[0].mozRequestFullScreen():$("#runtime")[0].msRequestFullscreen()?$("#runtime")[0].msRequestFullscreen():$("#runtime")[0].requestFullScreen()))
Then when you want full screen you just need to trigger this expression (from a button Click event, should be started by a user clicking the button)
Works for FullScreen!
I tried the following combinations two ExitFull Screen, Not Working..,
($("#runtime")[0].webkitExitFullscreen()?$("#runtime")[0].webkitExitFullscreen():($("#runtime")
[0].mozCancelFullScreen()?$("#runtime")[0].mozCancelFullScreen():$("#runtime")[0].msExitFullscreen()?$("#runtime")[0].msExitFullscreen():$("#runtime")[0].exitFullscreen()))
($("#runtime")[1].webkitExitFullscreen()?$("#runtime")[1].webkitExitFullscreen():($("#runtime")
[1].mozCancelFullScreen()?$("#runtime")[1].mozCancelFullScreen():$("#runtime")[1].msExitFullscreen()?$("#runtime")[1].msExitFullscreen():$("#runtime")[1].exitFullscreen()))
How I exit the FullScreen?
You can't control exiting full screen from within the page, should be the user with "ESC" keyboard key.
