How to enable local bound for thingshape property?
Hi All,
I am trying to enable local bounding with thingshape's property which is implemented on thing. How to enable local bounding with own thing property?
Ex. Created a thing "TestThing" with "ThingProperty" and Implemented "TestThingShape" with "ThingShapeProperty". Trying to enable local bound "ThingShapeProperty" with "ThingProperty". It was binded with "ThingProperty" but data was not updated.
Thanks & Regards,
Sathishkumar C.
Hi, Sathishkumar.
What version of ThingWorx are you using? There are no errors thrown in either the UI or the logs when you try this?
-- Craig A.
Thank you for your response.
I saw an error "Can not bind yourself" in application log.
Thanks & Regards,
Sathishkumar C
yes, even i am getting the same error when i tried same scenario at my local end.
error : Cannot Bind To Yourself
i think thingshape becomes values when it is implemented by some thing -- thingshape being alone doesn't make sense
so in our case when our thing implements that thingshape -- properties defined in both thing & thingshape are both confined to same thing entity.. thats why it gives the error : Cannot Bind To Yourself
but if you create another thing and bound the properties between these 2 things - bind happens
