Aug 8, 2024 7:16 AM UTC
How to export data in to excel from grid
Hi Everyone,
I have grid widget which data is populated through a SQL service, and I want to export that data which is in the grid into an excel file , can I do that if so then please share the solution.
Thanks and Regards,
Lavkush
PEHOWEAnswer
Aug 20, 2024 2:02 PM UTC
Hello @LY_10838955 ,
Exporting data from ThingWorx to an Excel format is not an OOTB supported feature.
If you are willing to create your own ThingWorx Extension,  the Apache POI library is a Java Library which can read and write Excel files.  Using the library and the ThingWorx Extension SDK, you can create an extension which Reads/writes from /to ThingWorx directly to an Excel file. The reading of data is also possible.  I have looked at this problem and may be able to provide some background if you have a developer which is interested in creating a solution.
Pehowe
Aug 8, 2024 7:38 AM UTC
Hi @LY_10838955
Please refer this link - Article - CS257590 - Is it possible to export data to Excel and PDF files in ThingWorx Platform (ptc.com)
To export as CSV file - Data Export (ptc.com)
/VR
Aug 8, 2024 8:10 AM UTC
Hi @Velkumar ,
Even if I want to export in csv form then how can i export because it is saying in csv we can export
so please suggest
Lavkush
Rocko
Aug 8, 2024 8:13 AM UTC
What is unclear about that? The second link describes in detail how to use the Data Export function to create CSV.
Rocko
Aug 8, 2024 7:49 AM UTC
You can use this extension: https://github.com/ptc-iot-sharing/DataExportExtensionTWX
