Jul 24, 2024 3:56 PM UTC
How to fetch 2000 rows of data from datatable in lesser time.
We are fetching almost 2k-3k rows data from datatable to populate in grid. It takes around 1 minute to populate data in tree grid. We also using data filter to filter data from datatable, it takes another 1 minute to filter data from datatable and to populate in grid. How to reduce the time when multiple users fetching data at same time in production environment.
Jul 25, 2024 1:31 AM UTC
Hi @AP_10343008  Create an index for each set of filter criteria commonly used under DataTable > Configuration > Index Settings
look at the below reference article.
https://www.ptc.com/en/support/article/CS363996?source=search
Rocko
Jul 25, 2024 5:51 AM UTC
Have you checked how that time is spent? Is it in execution of the service that gets the data, or in moving over the data to the client, or in the widget trying to render it?
Jul 29, 2024 7:14 AM UTC
In Grid, All child rows taken from datatable. But Parent rows and its values will be calculated dynamically during execution. As childrows are 2500 in count in datatable, it might take lots of time to add parentrows for every 3 or 5 childrows.
Rocko
Jul 29, 2024 7:39 AM UTC
As Surya wrote, try to use indexing, but to be honest, that's a lot of items to show in a tree...
You could also share your code so readers could look into it.
