Aug 12, 2024 7:41 PM UTC
How to find uncommon records in infotables without for loop.
I have infotable A and infotable B.
Ill compare data in both infotable A and infotable B.
Ill delete the matched records in both tables and the uncommon records remains in both the tables infotable A and infotable B.
How it can be done without using for loop?
Any infotable functions will be helpful?
Rocko
RockoAnswer
Aug 13, 2024 6:39 AM UTC
Even if you wouldn't use a for loop, one would have to be used internally, so it doesn't make a difference. You can't do this without iterating the values.
TBH instead of altering the infotables I would just create new ones. This is how you could compute A minus B, assuming you compare on column age.
If you need to compare every property, it's more complex.
let result = Resources["InfoTableFunctions"].CreateInfoTable();
result.AddField({name:"id", baseType:"STRING"});
result.AddField({name:"name", baseType:"STRING"});
result.AddField({name:"age", baseType:"INTEGER"});
let deleteTable = Resources["InfoTableFunctions"].Clone({t1:result});
let resultTable = Resources["InfoTableFunctions"].Clone({t1:result});
result.AddRow({id:"4",name:"A",age:10});
result.AddRow({id:"5",name:"B",age:20});
result.AddRow({id:"6",name:"C",age:30});
result.AddRow({id:"7",name:"D",age:40});
deleteTable.AddRow({id:"6",name:"C",age:30});
deleteTable.AddRow({id:"7",name:"D",age:40});
deleteTable.AddRow({id:"8",name:"E",age:50});
// until here it's just setting up some data. result would be Table A, deleteTable would be Table B
let delArray=deleteTable.rows.toArray().map(r=>r.id);
result.rows.toArray().forEach(row=>{ if (!delArray.includes(row.id)) resultTable.AddRow(row);});
result=resultTable; // A minus B, now repeat to do B minus A
Rocko
Rocko19-TanzaniteAnswer
Support
Nov 11, 2024 6:55 PM UTC
Hi @AP_10343008,
It appears that a response to this post answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
