how to fix error related to 'thingworx:temperature-thing:jar' in temperature-thing project
I'm trying to connect Thingworx to Raspberry Pi using temperature-thing example with Am2302 sensor.
Thingworx-common jar file has been installed manually, but running 'mvn package' gave the following error:
C:\Users\Lipi.Malladi\Downloads\temperature-thing\temperature-thing>mvn package
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building temperature-thing 1.0-SNAPSHOT
[WARNING] The POM for com.thingworxs:thingworx-common:jar:6.0.2 is missing, no dependency information available
[INFO] BUILD FAILURE
[INFO] Total time: 0.643 s
[INFO] Finished at: 2017-07-10T15:10:55-05:00
[INFO] Final Memory: 6M/15M
[ERROR] Failed to execute goal on project temperature-thing: Could not resolve dependencies for project com.ptcmanaged.thingworx:temperature-thing:jar:1.0-SNAPSHOT: Failure to find com.thingworxs:thingworx-common:jar:6.0.2 in https://repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
I have updated the link in pom file to: http://maker01.cloud.thingworx.com/mvnrepo
Please let me know how this error could be resolved. Thanks
Hi Fred, which Edge SDK are you attempting to setup? Seems like the class path configuration is incorrect
festes1-VisitorAuthor
Hi Sushant, I am trying to setup SDK version 1.0.0.38
