How to generate alerts on the combination of values of 2 properties.
  • September 20, 2016
  • 9 replies
  • 4279 views
I have 2 properties and I want that when the value of both these values cross a threshold value then only a alert should be generated and not just on one property.
Make a service that will check values of both properties and if both of them are above threshold , return true which you can be saved on another  Boolean property .
Generate an alert when this Boolean property is true.
Let me know if you find this useful.
You can create a subscription to value change on one of the properties or both, and there check the threshold, once detected the alert you can throw it by hand through a service, or build you own alerts system.
psaxena1-VisitorAuthor
How to generate an alert through a service, because there is no snippet as to generate an alert.
me.AddOrUpdateAlert
