Mar 30, 2018 5:11 AM UTC
How to get a table of distinct rows with all columns
Hello , can anybody help me?
I am getting the repeated data of perticular characterisrtics but i want data distinctly but not only columns but also a row.If anyone knows the solution then please revert back. I tried using distict but it only give column not rows.
for example: I am having following table attached in image
now If we distict the table using ProcessID and PartID then table must be attached in image
The table must show the same values of the same row.
Pankaj Phopse
Apr 2, 2018 5:42 AM UTC
Please follow the steps
1. Query the stream(info1)
2. Create an infotable with the mentioned fields(info2)
3. Add first row of stream to that infotable;
4. Put a loop(i) where the loop length is stream length.
5. Put a second loop(j) inside the first loop for which the loop length is new infotable length.
6. Put a condition to check whether the stream part id and process id is same as that of the values in the infotable.
eg: if(info1.rows[i].Part == info2.rows[j].Part && info1.rows.Process == info2.rows[j].Process)
                break;
      else
                Add data to infotable
 Try it!!!
Mar 30, 2018 1:45 PM UTC
Can you provide some further detail of your expected result here? I'm not quite sure what you mean.
Thank you,
-- Craig A.
6-Contributor
Mar 31, 2018 7:09 AM UTC
   Lets take an example I have one stream which stores the data. In the stream columns are Part,Process,ActaulValue and Deviated Value. Now in the stream the data is of 100 rows in that the part ID and Process ID are diffrent like I have 5 Processes suppose A,B,C,D,E and Part are F,G,H,I,J.
Now in the table I am getting duplicated data  accordingly. Now I dont want the duplicated data of the same Process and Part, for example if Process A in the table is 5times and the data accordingly like:
row Process  PArt  Actual  Deviated
1.    A              F     10       15
2.    A              G    11       16
3.    A             G     12       17
4.    C              F     13       18
5.    B              F     10       19
Now in the above table A is repeated 3 times but I want this A must be unique according to part like:
1.  A  F 10 15
2. A  G 11 16
3. C  F  13 18
Like for the same Part and Process it should not repeat I want each row must be distinct.
Thank you.
                break;
      else
 Try it!!!
