11-Garnet
Sep 10, 2025 4:06 AM UTC
How to get credentials from Azure Key Vault via ThingWorx
help required to  retrieve credentials from Azure Vault to thingworx, this will later be used to in Thingworx configurations.
please help.
Janakiraman
18-Opal
Sep 15, 2025 9:55 AM UTC
I wouldn't do this from ThingWorx if I were you. Cloud compute workloads rarely access secrets directly, and instead they expect to be configured from the outside. So I would instead create an Azure Function, which would access those secrets and inject them into your running ThingWorx instance via REST. You can then trigger that function manually or from your CI/CD pipeline.
/ Constantine
Sep 10, 2025 1:44 PM UTC
Hi @Janaki.Raman take a look at  From "Help Center" - "Step 7. Set Up Encryption for Azure IoT Hub Credentials": https://support.ptc.com/help/thingworx_scm_azure/r3.0/en/index.html#page/thingworx_scm_azure/azure_connector/c_azure_connector_set_up_encryption_for_azure_hub_credentials.html
18-Opal
/ Constantine
Emeritus
Sep 17, 2025 5:11 AM UTC
Hello @Janaki.Raman,
It looks like you have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
