Apr 22, 2022 1:48 PM UTC
How to get current mashup url at runtime
@MDUser, were you able to resolve this question? I have a similar need. I have a redirect page from a third party application in which they append parameters to the url, and I need access to those param values.
Apr 26, 2022 10:32 AM UTC
Hello @travman7777 ,
I have checked the query raised by the user you have mentioned in the description. Their rquirement could not be fulfilled since fetching the mashup name is not feasible in ThingWorx without using some hardcoding (like using mashup parameter for every mashup).
pls check the linked article if that helps you:
https://www.ptc.com/en/support/article/CS187026
Regards
Bhawna
Regards
Bhawna
Apr 27, 2022 9:30 PM UTC
Thank you for following up. Yes I can confirm that was the way we ended up accessing the paramters. Ie hard coding them in the mashup.  In our case this should be sufficient for the time being.
