How to get parameter values from raspberry pi to thingworx using twc agent?
  • January 7, 2016
  • 1515 views
Hi guys,
I have created a remote thing in thingworx and i also have the raspberry pi loaded with c sdk.i executed the twc agent from it and found some interaction to thingworx.the log in thingworx says connection is established.i have only one parameter for my thing. i just changed the app key and thing name correspondingly in the agent properties file.other than that no changes were made on the c sdk. also the "isConnected" field shows false.how do we make it true?
is there any additional settings needed in c sdk or thingworx composer to see my data on the mashup/composer?
thankyou
Anup, if the 'isConnected' property is false, then the connection was not successfully made. Please do check the connection settings/ configurations to make sure an active connection is in place. Do you have any logging enabled?
agprasad1-VisitorAuthor
Thanks Aanjan
I got it connected and i have successfully seen the data i sent from rpi in the mashup.
now i would like to integrate another code with the c sdk code. ie i have a successfully running two seprate codes in hand and i need to combine those two.since i havn't worked with the make files, can you tell me how i can do that?
