Feb 2, 2022 5:25 AM UTC
How to get response in json
Thingworx/Groups/ getting html response
how can i get json response by using this api in thingworx
nmutterAnswer
Feb 3, 2022 10:11 PM UTC
You need to add header
Acceptapplication/json
Then the response will be in json format. Not sure if this was the question.
What also works (but is not so nice) is to add "<host>/Thingworx/Groups?Accept=application/json" to the url. You can also add maxItems=<number> as by default only 500 items will be returned.
Feb 2, 2022 7:54 AM UTC
See page 54 in the attached manual - "Configuration API Service — Content Retrieval (JSON Response Structure)".
Feb 3, 2022 9:44 AM UTC
How to get Json result from Infotable in thingworx while using any rest api of thingworx
nmutter17-PeridotAnswer
