How to get response of one service into another service
I have created two things
1 Device
2 Databasecontroller
1. In first thing(Device) I have written below code in service.
    let result = jsonmessage;
2. In second thing(DatabaseController) I want response of Device thing service using below code
    var serviceName = "ConvertData";
    let result=Things["Device"][serviceName]();
it is returning blank data.
22-Sapphire I
You can call the first service from the second service.
 How to pass one service data(response) to another service?
22-Sapphire I
A service has a return, so in the second service set whatever you want to output as the result and set the output to the proper base type.
