Jun 19, 2017 6:30 AM UTC
how to get the last 5 entries from the data table
hello I am having a data table into which values are being inserted at regular intervals.
I want to show last 5 entries of the data table.
Jun 19, 2017 8:37 AM UTC
Hi dibya ranjan mishra​,
Data table is not queried based on timestamp. As per my understanding you should use Stream so that Data can queried based on time and last 5 entries can be fetched.
If you are using Streams; you can simply use GetStreamEntriesWithData and set oldestFirst as false and maxItems as 5.
For Data Table you will have to create your own custom query to find the last 5 entries; Performance could be low.
You could try following:
Read the data for last x hours based on frequency of Data. Then sort the infotable based on timestamp (desending) and then read first 5 rows.
I hope it helps.
Jun 19, 2017 8:53 AM UTC
Here is what I did to fetch the last 5 records:
// result: INTEGER
var length = me.GetDataTableEntryCount();//your starting ID +length will be the last record ID
var query = {
  "filters": {
    "fieldName": "id",
    "type": "GE",
    "value": length-4
var params = {
maxItems: undefined /* NUMBER */,
values: undefined /* INFOTABLE*/,
query: query /* QUERY */,
source: undefined /* STRING */,
tags: undefined /* TAGS */
// result: INFOTABLE dataShape: "undefined"
var result = me.QueryDataTableEntries(params);
This is based on that you have a sequenced ID(start from 1 for example, and increased by 1 every time there was a new entry, or you change the code according your ID generator)
Hope it will helps,
Br,
Anna
Jun 23, 2017 8:43 AM UTC
Is there still anything issue with your service? Please let us know if further assistance needed.
Br,
Anna
