How to get the value centered in Value Display widget
There is no option  available that i can the height of the value centered do someone know another way to solve this ?
22-Sapphire I
Does the widget have a property called 'padding' you should be able to use that if it has it.
Sadly there is no property called padding in the value display .
22-Sapphire I
Then you would have to do it in CSS probably.
Support
Hi @NN_10375125.
Which version of ThingWorx are you running?
--Sharon
