How to get Thingworx login token
I'm writing a web application and need to get a user login token to call api ...
(Not use appkey, require user login with username and password then return a token.)
How can I do that?
22-Sapphire I
Is this token generated by an API call?
Would first auth into ThingWorx, make the call for a token after that and then pass that token in the API call for the information that you need.
vxba1-VisitorAuthor
Correct, token return from login API call, then use that token to call another API services.
Is it possible?
22-Sapphire I
Since tokens are usually valid for a certain amount of time, I would say yes.
You can temporarily store the token in a property and use it in your other services/API calls.
When the call returns an error you make another call for a new token.
Support
Hi @vxba.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
