how to give selected row values to another mashup
How to send the particular column value of  selected row of a grid in Mashup1 to Mashup2 label?
Please help me achieve this.
Shalini V.
slangleyAnswer
Support
Hi @svisveswaraiya_285988.
Without knowing more about your use case, take a look at these links from the Help Center to see if these may help:
Configure Mashup Parameters
Session Parameters
Keep in mind that the session parameters are stored in memory, so storing a single column value should be ok but storing entire infotable properties could lead to performance issues.
--Sharon
slangleyCommunity ManagerAnswer
Support
Session Parameters
--Sharon
Support
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
