7-Bedrock
How to have column headings in a table-style Collection Widget
I am using a collection widget to display items in an info table and a chart. However, it only displays the rows and I am unable to display or put on any column headings.
To clarify, I am using a collection widget and not a grid widget since I wanted to add shapes in the table, where the color changes based on a column's value.
This is what the parent mashup looks like:
The workaround that I did was that I added a container above the collection widget which has the column names that I want.
However, that didn't work well since the column headings do not align with the columns in the container widget, as seen in the image below (mashup on runtime):
I have tried just resizing the containers but it still did not work well and it does not seem like a good idea since it will just be based on my screen size.
Could someone please tell me how can I solve this?
Thank you in advance.
AshrithaAnswer
Approach  followed is correct, but column width has to be fixed ( last column width can be responsive)
Steps:
1. Add a container above collection widget- add multiple columns for header with fixed width.
2. In collection cell mashup , create columns same width as that of header
Hope this helps!!
Ashritha15-MoonstoneAnswer
Steps:
Hope this helps!!
S_Elsayed7-BedrockAuthor
7-Bedrock
Works perfectly. Thank you!
