How to hide horizontal scroll bar in Grid
Hello everyone
Could anyone help me hide the horizontal scroll bar in Grid?
Thingworx Version: 9.4
 /VR
abandalAnswer
Support
Hello @Velkumar ,
Could you please confirm which Grid widget you are using? Is it the Advanced Grid widget or the Grid (new grid) widget?
If you are using the Advanced Grid widget, then as a workaround, please try to use the New Grid widget. Also, for more information, please refer to this article: Article - CS400983 - Unable to disable the horizontal scrollbar on a legacy Grid Advanced widget, even though the widget is wide enough and there is no space to scroll to the left or right in ThingWorx Platform 9.3.4 (ptc.com)
abandalCommunity ManagerAnswer
Support
Hello @Velkumar ,
Velkumar19-TanzaniteAuthor
Hi @abandal
It is a new Grid in Thingworx 9.4
/VR
Support
Hello @Velkumar ,
As a workaround, you can enable the "ResizeColumns" property for the grid widget and try to reduce the width of columns. If you reduce the width of columns, then the "Horizontal Scroll Bar" will disappear.
(Refer to the below screenshot):
Please let me know if the workaround provided above works for you. Also, if you have more to share on your issue, please let the Community know so that we can continue to support.
Hi @abandal
The problem is scroll bar doesn't disappear once we resize the column in Runtime.
When the grid gets loaded this is how it looks (without scroll bar)
After resizing any one column, the horizontal scroll bar never disappears even after making all columns to minimum width in runtime.
/VR
Support
Hello @Velkumar ,
Could you please provide all the required entities (.xml files) to reproduce this issue? I will try to import it into my ThingWorx Composer and will try to troubleshoot this issue.
Abhi
