how to implement custom login functionality
I have a requirement to implement customized login page,I tried to customize Thingworx FormLogin but it was not upto my requirement. Need suggestions Thank you
Hi @ashokq not sure if you have already tried this knowledge base article How to customize login page in ThingWorx.
ashokq1-VisitorAuthor
Hello @supandey
Thanks for you are response,I had an idea about this.But when i change the login page it will effects  globally,In my case i need to implement this for particular organisation only. That is the reason i choose this to implement customize login using thingworx,I designed mashup and trying to implement Login functionality.
Have you tried setting your Login mashup as the Home mashup of the Organization. I haven't tried it, but i believe the Home mashup will be used as the Login page for Users under that Organization.
