Sep 16, 2025 11:34 AM UTC
How to Implement Drag-and-Drop Marker on Image in ThingWorx Mashup Runtime
We’re working on a work instruction mashup in ThingWorx where the user needs to drag and drop a marker onto an image to indicate the specific location where an operator should perform a task.
Is there a recommended way to implement this functionality within the ThingWorx Mashup runtime?
Are there any widgets, extensions, or best practices that support drag-and-drop interaction over images?
Any guidance or examples would be greatly appreciated!
VladimirNAnswer
Sep 16, 2025 8:05 PM UTC
Similar questions:
VladimirN24-Ruby IVAnswer
Similar questions:
Support
Sep 22, 2025 7:37 PM UTC
Hi @JV_11087733
It appears that this post may answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Abhi
