Apr 26, 2025 6:25 AM UTC
How to Implement File Upload and Repository Display in ThingWorx Mashup?
I want to design a file storage feature using a repository to store user-uploaded files (PDF and PPTX formats).
When a user selects a file and clicks the upload button, the file should be saved into the repository. After the upload, the stored files should be displayed in a grid table within the Mashup.
How can I implement TW?
kindly give me a end to end example.
i am using TW version
Apr 29, 2025 7:29 AM UTC
User File Upload Widget  to upload and mange files from Mashup.
Apr 28, 2025 1:30 PM UTC
HI @SV_13015361 ,
The File Repository is the thing you need here, and it's already in the platform, you don't need to design something new for that. I'm not be able to share a complete end to end example, as that is typically the job of a developer, but I can share with certainty that if you go through the basic ThingWorx platform training, you will be able to achieve this use-case fast - probably less than a day based on what I see here.
Please reach out to your PTC contact (or if you don't know that person, someone within your company that was marked as the main HP contact person with PTC) and they would be able to guide you specifically to the trainings you require.
Emeritus
May 2, 2025 9:45 AM UTC
Hello @SV_13015361,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
