How to implement separate schedules for each user
dear  all expert
i plan to multiple users  dynamic scheduling every user separate scheduling time how to implement. i have done for single user   email sent massage scheduling. but how did multiple user and dynamic scheduling  email sent .
wcuiAnswer
Try below code to dynamically create scheduler thing.
var ThingName = "yourThingName";
var params = {
name: ThingName /* STRING */,
description: undefined /* STRING */,
thingTemplateName: 'Scheduler' /* THINGTEMPLATENAME */,
projectName: 'PTCDefaultProject' /* PROJECTNAME */,
tags: undefined /* TAGS */
try{
Resources["EntityServices"].CreateThing(params);
logger.warn("Thing Created: "+ThingName);
Things[ThingName].EnableThing();
updateThing();
Things[ThingName].RestartThing();
Things[ThingName].EnableScheduler();
catch(e){
logger.warn("Exception"+e);
function updateThing(){
var configtable = Things[ThingName].GetConfigurationTable({tableName: "Settings"});
// update configuration with service parameters
configtable.schedule = '0 0/10 * * * ?';
configtable.runAsUser = 'Administrator';
configtable.enabled = true;
// set new configuration table
var par= {
configurationTable: configtable /* INFOTABLE */,
persistent: true /* BOOLEAN */,
tableName: "Settings" /* STRING */
Things[ThingName].SetConfigurationTable(par);
Hi @Hariharasuthan
Could you please elaborate on your use case?
Also, give some information on the below question
1. How many users will be using this feature
2. How do users define scheduling time from UI / Mashup?
/ VR
hi @Velkumar
 answer question
1.N number of users use feature. , (Multiple user multiple chose the (hour,day,week,year,) all are separate  configuration  )
 2, define user from UI/mashup ( hour ,week  ,month ,year ) scheduling save value to SQL server
          use case. Elaboration:
n number of users continuously joint in database, each user some configuration need configuration means report sent to the mail time periods(hour,day,month,year) this store value from sql server , N0 user one hour sent mail N1 user two hours N3 user one day N4 user week  N5 user month N6 user year N number of user all are (hour, day,week ,month ,year) based
for example :
n1 user sent mail every one hour
n2 user sent mail end of day
n3 user sent mail weekly once
n4 user sent mail monthly once
n5 user sent mail yearly once
requirement
 i attempted to single user scheduling (hour,day,month,year) sent mail successfully. run on this concept.  ,but n number of user how to implement scheduling.
With Regards
Hariharasuthan
