22-Sapphire I
Please do a search through the Forum as there are plenty of articles on importing JSON
but similar to the XML example, there is a content loader function to retrieve JSON content
Thingworx will automatically make that into an object.
Please note if the JSON is an array at the top level, Thingworx will add a level called array
i.e. jsonObject.array.[your json structure here]
shreekant1-VisitorAuthor
Thanks for your reply. But as I said that I am a beginner to this, I am not sure from where to start. I have followed getting start guide and created dashboard on hosted server. Now I want to use same example but just want to add .json file instead of .xml file. It would be much helpful for me if you let me the steps for doing this.
shreekant
Greetings,
Is there a particular TWX DevPortal guide with which you're having issue?
Are there specific instructions that aren't working correctly?
If so, please provide us with a URL of the guide in question, and we'd be happy to investigate.
Thank you,
Jason
