How to insert or Add values in between Two rows in a Grid widget
I need a requirement like is there any possible way to add values in between two rows in grid widget.
In Grid i research a lot to insert a value in between two Rows.
Required assistance for the query .
Hareef.
kazunariAnswer
The easiest way is to sort the table after row insert. You can enable sort in configuration(from gearbox icon) in Grid widget.
kazunari12-AmethystAnswer
