11-Garnet
How to know if a property of a thing is a transformed property
I need to know if a property of a thing is a transformed property to show it in a mashup.
When you create a property, you can select if it's Direct or Transformed. Is it possible to know that information of the property using a service? And if not, how could I get it?
Thanks in advance
Hi, are you referring to the Transformed property from Platform Analytics services, the medium, min, max value summariezed from a data stream?
11-Garnet
Yes. It is a tranformed property from Platform Analytics services.
You may add some info in the property definition, and then you can retrieve it from API.
The configuration part is not revealable from API
Support
Hi @aetxeberria.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of other community members with the same question.
--Sharon
