how to load imagelink fieid in infotable
 hi experts
I wanna load image in infotable. There are 4 field names in datashape.
one of the four is imagelink type.
How can I load an image on infotable?
mneumannAnswer
Hi @JackEom
In the DataShape you can choose to implement
  • Image - to choose an image from your disk when setting the property
  • ImageLink - to choose a Media Entity already uploaded to ThingWorx
If you try to implement it programmatically, you can also create a new Property on a Thing with the InfoTable Type and a DataShape that contains both (Image + ImageLink) to check the differences before coding it.
mneumann16-PearlAnswer
Hi @JackEom
JackEom1-VisitorAuthor
 Thank you mneumann!
Your advice is very helpful.
