How to loading CSV file in exponential expression.
Example
A(G)  B (G) C (G)
0.007297 1.04E-05 3.00E-06
0.007924 6.86E-06 2.10E-05
This is CSV data example.
If i make loader. Can Thingworx handle it?
if not i will make translate data like this.
1.04E-05  --> 0.0000104.
how to do this case?
Hi @jaiminLee
ThingWorx, using the CSVParser, will be able to read the values.
I did a quick test and here is the result:
CSV file:
A B C
Result in AdvancedGrid widget:
Same code as in this post has been used to load the csv.
Hope this helps
Christophe
