How to log specific user activity
1. I wondered how can I log specific user name activity - save in known stream, lets assume the activity is logged in the Application log.
2. I created new appKey and assigned specific user to it, this appKey is used for executing rest call, I can see the request in the application log, for example:
Executing request [URI: /Thingworx/Things/myThing/Properties/Property1]
I want to save this row in a specific know stream, how is it possible?
22-Sapphire I
In the security log if you set the level low enough, you can see all requests by any users.
it is a bit dangerous because it can overload your logs and then the system potentially.
You could also add some services on each mashup and on each executed service that write to a stream
aelgov1-VisitorAuthor
Hi Pai,
Thanks for the information but you are not answering my question
