how to make display name of button auto selected once we view mashup?
I am trying keep display name of button bar auto selected once we load the mashup.
Right now we need to select it manually by hitting the button bar.
so my requirement is ...suppose there are 2 display names in button bar and i want to keep first display name in button as auto selected one the Mashup is loaded or opened.
can anyone know how to do it
VelkumarAnswer
Hi @Suraj_Patil
Pass the selected Value from the text field widget or expression to select the default value when you load / open mashup
/VR
Velkumar19-TanzaniteAnswer
Hi @Suraj_Patil
/VR
this is the one way i know about ...is there any other solution to this like by default check box in properties or something?
@Suraj_Patil  I don't think we can put it in widget properties. The best option would be to put text field widget and make it invisible
