How to make the mashup screen more responsive
Here, the problem is with placing widgets on the layout through panel widgets and thus that widget becomes non_responsive and we are having to position those widgets in accordance with the screen resolution chosen.  It would be helpful if someone could give some inputs on making the mashup screen more responsive.
is it possible to only use Layout widget?
muzzammil1-VisitorAuthor
no..coz..when u go for using widgets like value display or label or led display widgets, panel widget usage becomes necessary..
In ThingWorx, Label and LED Display must be placed in Panel, Value Display can be placed in Layout.
Can you share some screen to show your target design?
Hi
With your widgets that need to be on a panel, have you tried using a panel on a panel?
In your case I would make use of the layout widget as well as the panel on panel method.
regards
I have tried panel on the panel method, but it's worse than before. And it still doesn't resolve the issue.
Would you mind sending a screenshot of what it is you are trying to make more responsive, if i have a better idea of it, I can try and make my answers more specific.
Regards
