Feb 23, 2017 8:55 AM UTC
How to Navigate ASP.NET webpages to Thingworx dashboards. Is it possible?
I have web application which developed by using ASP.NET . I want to navigate from .NET web pages to Thingworx dashboard. is there any possibility to do that.
Feb 23, 2017 10:01 AM UTC
Hi Spandhana, if the question is just about navigating you could use the URL to the Mashup that contains the dashboard for navigating. Something like this http://<serverName>:8080/Thingworx/Runtime/index.html#mashup=DefaultMashupToEditGadget
Have you already tried that?
Mar 3, 2017 5:03 PM UTC
Spandhana,
Any update on this? Was Sushant Pandey's post helpful? If so, could you click on the "correct answer" or "mark as helpful" button and let us know?
sdaram-21-VisitorAuthor
Mar 10, 2017 10:10 AM UTC
My Issue Got Resolved. I am able to Display Thingworx Mashup in Iframe Control of my Webpage.
Steps I have done
1) I have followed below step mentioned in Release notes.
Description
Required Steps
Remove all clickjacking protection
  1. a. Locate the following section of code in the web.xml and comment it out:
  2. b. <!-- use the SameOrigin version to allow your
  3. c. application to frame, but nobody else -->
  4. d. <filter-mapping>
  5. e.        <filter-name>ClickjackFilterSameOrigin</filter-name>
  6. f.        <url-pattern>/*</url-pattern>
                 </filter-mapping>
Currently i am using Thingworx 7.3
2)
<iframe id="if1" width="500" height="390" style="visibility:visible" src="http://localhost:8080/Thingworx/Mashups/PGCGraph? appKey=0f4b4662-7d09-46c3-a766-bbbcfa73ad99&x-thingworx-session=true"></iframe>
Mashup URL I am giving like this
here PGCGraph is Mashup Name.
I have Created User (Example:User123) and I Have created Appkey( 0f4b4662-7d09-46c3-a766-bbbcfa73ad99) and assigned created user (User123 to appkey.)
3)For Mashup i have assigned user in Design Time and Run time Permission.
With above steps i am able to get my mashup in iframe.
Spandhana Daram
