how to pass dynamic value for datatable columns
Iam checking each row of datatable in for loop.
So iam using code: resultDT.rows[i].XXXXX
I stored the field definitions in array arr[] inside the same service. I want to pass them dynamically inside for loop to the code resultDT.rows[i].XXXXX . I dont want to hardcode them again. How to make this possible?
TonyZhangAnswer
Support
Hi @AP_9467111,
Please find below sample code to see if that gives you some clues.
// Suppose you have arrays contain data for each column.
let column1Array = ["a","b","c","d"],
    column2Array = ["e","f","g","h"];
// Create Infotable from DataShape
let infotable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    infoTableName: "InfoTable",
    dataShapeName: "SampleDataShape"
// Loop through the first array
column1Array.forEach(e => {
    // create new entry in Json format
    let newEntry = {
        Column1: e,// STRING [Primary Key]
        Column2: undefined// STRING
    // add entry to Infotable
    infotable.AddRow(newEntry);
// update rest columns of each infotable row
infotable.rows.toArray().forEach((row, index) => {
    row.Column2 = column2Array[index];
// add infotable entries to datatable
me.AddOrUpdateDataTableEntries({
    sourceType: undefined /* STRING */,
    values: infotable /* INFOTABLE */,
    source: undefined /* STRING */,
    tags: undefined /* TAGS */
TonyZhangCommunity ManagerAnswer
Support
Hi @AP_9467111,
    let newEntry = {
Support
Hi @AP_9467111,
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Tony
