Aug 1, 2023 4:29 PM UTC
How to programmatically create a scheduler
Is it possible to programmatically create a Scheduler in thingworx 8.5.3?  I saw the following article, but I don't see this template in 8.5.3.
https://www.ptc.com/en/support/article/cs382629
I'd like to create a mashup where users can schedule email reminders for preventive maintenance.  The emails will be sent out to the users on the scheduled date/time.  In order to implement this, I think I need to be able to create a scheduler programmatically, where the subscription on the scheduler would be created automatically as well.
Aug 2, 2023 5:17 AM UTC
Hi @Willie
'Scheduler' ThingTemplate is part of Thingworx. It cannot be deleted or removed from Thingworx. It should be available in Thingworx 8.5.3
Try to search/find the template using the Administrator account. If you cannot find it please create a PTC support ticket.
For your use case:
  1. Create Scheduler ThingTemplate say 'emailSchedulerTemplate' with a subscription to trigger email.
  2. On Mashup when the user configures a reminder, create a new Thing based on 'emailSchedulerTemplate' and update its CRON string based on user input
/VR
Willie16-PearlAuthor
Aug 3, 2023 5:08 AM UTC
Hi @Velkumar
I was able to locate the 'Scheduler' thingTemplate and create a scheduler with the steps provided.  Thank you.
When the subscription is triggered, the email is sent out and the scheduler is supposed to delete itself.  I have the following line at the end of the subscription, but the scheduler doesn't delete itself.  Do I need to get another thing to delete the scheduler?
Resources["EntityServices"].DeleteThing(me.name);
Aug 3, 2023 5:39 AM UTC
Hi @Willie
Above mentioned code should work. Do you see any error when you execute the service manually?
/VR
