How to put Values into Stream, Value Stream, Data Table
Hello Peoples!
I would appreciate if somebody could help me understand these basic TWX functionalities.
More or less I understood the difference of the 3 items above.
But im still struggling in using them.
Ive seen the "Add value entry" Snippet in Services/ Subs, but I was not able to create new entry for a stream.
If there is a tutorial or similar Post in this forum, or if u already master these 3 Data Mgmt-tools,
please help learn to use them.
Thanks in advance
Igor
Hello Igor,
We have a very helpful article that explains the differences between streams, value streams, and data tables and recommends the services needed to add data to each. Please find the link to the support article below.
https://www.ptc.com/en/support/article?n=CS204091&posno=4&q=value%20streams&source=search
-Saeed
20-Turquoise
We have an example here on how to use the addstreamentries code snippet. Hope it's helpful
https://community.ptc.com/t5/ThingWorx-Code-Examples-Platform/AddStreamEntries-snippet-service/m-p/533577
igor11-VisitorAuthorAnswer
