How to read csv/excel file that reside on network path instead file repository
I have some requirement like How to read csv/excel file that reside on network path instead File repository.
Example:
In below example you can see I want to read a csv file 'EmpDetails.csv' that reside under path 'C:/Users/NG6F868/Desktop' instead File Repository  'EDURepository' but I am getting error 'Wrapped com.thingworx.common.exceptions.InvalidRequestException: File Repository [C:/Users/NG6F868/Desktop] Does Not Exist Cause: File Repository [C:/Users/NG6F868/Desktop] Does Not Exist' when I test the service.
var params = {
    path: 'EmpDetails.csv' /* STRING */,
columnMappings: 'FirstName,LastName,DOB' /* STRING */,
    hasHeader: true /* BOOLEAN */,
//longitudeField: undefined /* NUMBER */,
//dateFormat: undefined /* STRING */,*
    fileRepository: 'C:/Users/NG6F868/Desktop',
//fileRepository: 'EDURepository' /* THINGNAME */,
//latitudeField: undefined /* NUMBER */,
fieldDelimiter: ',' /* STRING */,
//stringDelimiter: undefined /* STRING */,
dataShape: 'EmpDetailsDataShape.csv' /* DATASHAPENAME */
// result: INFOTABLE
var result = Resources["CSVParserFunctions"].ReadCSVFile(params);
Is there any way to fix this issue and fulfil my requirements?
Please do the needful as soon as possible.
From,
Rohit Kumar Jaiswal
Try the GetCSVFile service (part of CSVParserFunctions) where instead of using a ThingWorx file repository you can supply the file URL. I don't think you can refer to a local path on your computer, though, as TW wouldn't know anything about that.
Okay,
Is there another way to read data from CSV/excel file and store data into Infotable or Datatable in Thingworx? I got stuck in my project due to this.
Please give me solution for the same.
Thank you in advance
