How to read CSV file from System repository using script
Hi Team,
Suppose I want to read any csv file present in system repository and then parse it into a infotable then how would it be done using script?
Thanks in advance.
odukiyaAnswer
Hello @ranjank
May be you can use CSV parser extension for the same from our support portal. Please refer following help center guide which provide more detailed information about its services.
https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Extensibility/CSVParser.html
Let me know if it doesn't answer your query or you have further concern.
Om Dukiya
odukiya16-PearlAnswer
Hello @ranjank
Om Dukiya
Support
Hi @ranjank.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
