How to read the mysql data to the generic thing properties in the Thingworx (9.3.0) ?
I have the Thing which is connected to the mysql database and I am able to retrieve the data to the thingworx mashup by writing the services in the database thing.
So now i need to get the parameters value of the mysql database table in the generic thing where the properties .are there
instead of getting the data from the database thing by fetching the data through the services , can we get the parameters values into thing properties which should be updating every time when the new data is logged in the database.
If anyone have tried this, please help me to sort out this issue.
Shree
VelkumarAnswer
Hi @NH_shree
As I said earlier use Timer / Scheduler Event (based on your requirement) to execute the update script.
For example: If you want to update property value every 5 mins
1. Create a TimerThing with Timer Template
2. Set the update rate to 300000 milliseconds (5 mins)
3. Create a subscription in Timer Thing with Timer Event
4. Call propertyUpdateScript in Subscription
So property value will be updated every 5 mins
Note: Fetching data from DB with a low update rate (say every second or 2) will cause performance issues.
/VR
Hi @NH_shree
I don't think we can get new logged data events/triggers from DB.
Maybe based on your requirement you can create a scheduler and update data from the Database to Thing Property
/VR
NH_shree14-AlexandriteAuthor
Hi @Velkumar ,
Right now i am able to get the data updating on the mashup but it is not the historical data which will store in the query property history because i have the thing which is directly fetching the data from the database through the sql queries written in the services .
I need to get the historical data which will be also stored in the thing properties so that the thing can be used in the vuforia  AR /VR experience , so how can i get the mysql data to the generic thing template properties ?
Shree
Hi @NH_shree
What do you mean by you want to store historical data in Thing property?
Do you want to store all rows from DB to store in the Thing property or only the latest value should be stored in the Thing property?
/VR
