Hi @MM_9023322
Since Thingworx is configured in the UTC timezone, you can convert PST to UTC and set the scheduler CRON string accordingly. For example: When PST is 00:00, UTC will be 07:00. So you can set the scheduler to trigger at 07:00 UTC for the facility in Sacramento.
Create a new scheduler for each facility and update the CRON string based on the facility timezone
If scheduler configurations are updated from Mashup / Runtime, you can get the client browser timezone difference and convert it to UTC to update scheduler configurations.
/VR
