Jamal Ashraf
Nov 26, 2025 12:50 PM UTC
How to receive and process XML data in a ThingWorx service (via external SAP API call)?
 Hi everyone,
I’m working on a use case where our SAP team wants to send data to ThingWorx via an HTTP API call. They will post the data as XML, and ThingWorx should receive it in a service, parse it, and store the information in a DataTable or Dataset.
However, I’m not sure how to receive the XML payload properly inside a ThingWorx service. When SAP calls my service endpoint, I don’t see any way to directly access the raw XML content — it’s either not recognized or comes as an empty input parameter.
What’s the correct approach to handle this in ThingWorx?
Specifically:
How can I receive XML from an external system in a ThingWorx service?
Do I need to configure a specific Content-Type header (like application/xml)?
If anyone has done SAP → ThingWorx integration with XML payloads, I’d really appreciate an example or best-practice recommendation.
Thanks in advance!
PEHOWEAnswer
Dec 12, 2025 9:43 PM UTC
Hello @MA8731174 ,
I have reviewed your issue with the Support team.
It appears that when the XML is input into ThingWorx it is being parsed. This parse is what is causing the issue. One solution would be to have the source encode the XML. You have indicated that is not an acceptable solution.
A work around would be to construct a JSON which contains the XML.
One method of doing this would be to create a Micro Service which accepts the XML and performs the encoding of Percent and then pass the value ThingWorx.
I have an  export of the testing services from POSTMAN, and ThingWorx export of the thing used in our testing. I will be attaching them to a separate post
Please let me know if you have any questions
Pehowe
Jamal Ashraf
Nov 26, 2025 12:53 PM UTC
We solved it by setting the Content-Type to text/xml  and accept  text/xmland creating a ThingWorx service with an input parameter content of type XML.
In the REST API call, I added the flag ?postParameter=content — and now the XML payload from SAP is correctly received inside the service.
Jamal Ashraf
Nov 27, 2025 8:48 AM UTC
I am facing another issue now while processing the XML payload received from SAP. There are several tags (around 4–5) that contain the % character. When these tags include the % sign, the request fails with an “unable to parse XML request” error.
I am already sending the correct headers:
  • Accept: text/xml
  • Content-Type: text/xml
If the % character is removed from the payload, the request is processed successfully and I receive the expected XML response.
Could anyone please advise how we should handle or encode the % character in the XML so that the request can be parsed correctly?
Rocko
Nov 27, 2025 12:24 PM UTC
Tagnames in XML can't contain the % character per definition. That problem should be solved at the source, not the destination.
18-Opal
Nov 27, 2025 3:09 PM UTC
% is an XML entity, try encoding it as  % on SAP side.
See https://en.wikipedia.org/wiki/List_of_XML_and_HTML_character_entity_references
Jamal Ashraf
Nov 28, 2025 10:14 AM UTC
With CDATA it works as below
![CDATA[%]]
but if i write &percnt in a tag then error as below
406 not acceptable
I ll contact SAP team about it Thank you!
Rocko
Nov 28, 2025 10:54 AM UTC
Maybe also check you are not running into the ESAPI validation issue as earlier. https://support.ptc.com/help/thingworx/platform/r10.0/en/#page/ThingWorx/Help/Installation/ConfiguringESAPIValidatorSettings.html
