How to recieve data from Thing property to Arduino?
Hey everyone, i have a problem that i ve tried to solve for a week and the thing is I can send data using Arduino+IntelEdison with some sensors but i have clearly no idea how to Recieve data from ThingWorx Thing property. Can anyone show some example how to do this because i have no clue how. Thank you in advance
asmirnovAnswer
Thank you for response
Anyway myy problem has been solved by changing accept data format from text/html to application/json.
Hi Andrew, i believe this use case is covered quite in detail in this blog DeliveringArduinoDataToThingworx.pdf have you already seen this? It may be not an exact match to the hardware you have but the idea is the same.
Hope this'd help.
asmirnov1-VisitorAuthorAnswer
