How to remove space from Line chart widget in Thingworx 9.3
Hi all,
I am using a line chart widget, and I want to remove the extra space from the 0th of the x-axis to the x-axis tick label.
I have used the below CSS to fit in the chart from all sides.
ptcs-chart-line::part(chart-layout) {
padding: 0;
The image is attached with the query.
Thank you!
Hello @MM_9023322 ,
The same query has been answered priorly. pls check the given link:
https://community.ptc.com/t5/ThingWorx-Developers/Spacing-Issue-in-Line-Chart/td-p/766237?posno=4&q=line%20chart%20space&source=search
BR
Bhawna
