Oct 19, 2015 8:51 PM UTC
How to return a small datatable
I have several small calculations that I would like to do.  I can easily write a service for each of them and return an single value.  I would like to have one service and just return a datatable of all of these values.  Does anyone have an example on how to do this?  I have found a few snippets of code, but I can't seem to get the syntax correct.  Thanks!
P.S. Did the Correct Answer button disappear with the forum update?  I don't see it anymore.
Oct 19, 2015 9:41 PM UTC
Create a DataShape with the fields that you want to return, let's name it MyShape, which has two fields: columnName1, columnName2.
Then create a new service which should look like:
var value1 = me.ServiceCalculation1();
var value2 = me.ServiceCalculation2();
var result =  Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
          infoTableName: "InfoTable",
          dataShapeName: "MyShape"
result.AddRow({
    columnName1: value1,
    columnName2: value2
Of course the Return Value for this service should be InfoTable with DataShape: MyShape.
result.AddRow({
    columnName2: value2
Oct 21, 2015 8:22 PM UTC
byutz - just wanted to confirm you were able to find the correct button. Let me know if you have any other questions about the ThingWorx Community​ upgrade over at the Community Hub​.
