Feb 9, 2016 8:56 PM UTC
How to return MAX() from a specific field in Data Table?
I'm trying to create a service that I can globally put in a ThingShape; then reference inside every new DataTable that I create. This service will find the PK of each new data table and ensure that it is populated with a unique/increasing value. To do this, I need to be able to find the current MAX() value of all data in the data table for the PK field; then set new row PK field to MAX()+1.
If I'm simply way out in left field...please reign me in, but I think I'm close.
Please provide a sample script for how to query this information from an existing data table.
PaiChungAnswer
22-Sapphire I
Feb 10, 2016 12:06 PM UTC
So to find out what Aggregate puts out, you can always first set the result to the Aggregate (basetype infotable) and see the result in Composer.
Aggregate pre-pends the operation before the field it is acting upon.
So newID = dtMax.MAX_KEY_Field
22-Sapphire I
Feb 9, 2016 10:19 PM UTC
The Aggregate service can give you MAX (as well as MIN COUNT AVERAGE SUM)
chrish1-VisitorAuthor
Feb 10, 2016 2:50 AM UTC
Ok, almost there!  dtMax variable is a INFOTABLE with exactly 1 row and 1 column. How do I set the variable "newID" to the single numeric value of dtMax?
    var dtParams = { maxItems: undefined /* NUMBER */  };
    var dtValues = me.GetDataTableEntries(dtParams); //INFOTABLE
    var newID=0 // NUMBER
    var dtMaxParams = {
        t: dtValues, // INFOTABLE
        columns: KEY_Field, // STRING
        aggregates: "MAX", // STRING
        groupByColumns: undefined // STRING
    var dtMax = Resources["InfoTableFunctions"].Aggregate(dtMaxParams); //INFOTABLE
    newID = ????
PaiChung22-Sapphire IAnswer
22-Sapphire I
