How to select all rows in advance grid using select all checkbox?
Hi
I am using Thingworx 8.1 and I want to check all rows using select all checkbox in advance grid can you please suggest what is the way to do it. I have already refer this article but I don't want to select rows this way.
When I check select all checkbox I want to select every rows(Sr column) of checkbox in advance grid.
Can you please suggest.
Hello @DT_316496 ,
The article that you have mentioned in the description works well in every use cases. However, After reading your query completely i have understood that you are tying to select a column by checking the select all.
Can you please confirm once?
Regards
Bhawna
DT_3164961-VisitorAuthor
Hi @bchaudhary_448008 ,
Yes I am trying to select a column by checking the select all checkbox.
Hi
Can anyone here who can suggest above solution.
