How to send data to Google Map extension
I use google map extension 3.1.7 in ThingWorx 9.3.2.
I having a problem using the tooltip, I can't send data to mashup.
in mashup  tooltip i add parameter configure mashup
Please suggestion me how to pass data to tooltip.
Thanks you.
VelkumarAnswer
Hi @Chanin
I think the issue is with Google Map Widget version - 3.1.7. Even though in the changelog it is mentioned that issue got resolved but the issue still exists
When I checked with Google Map Widget - 3.1.1 I'm able to assign value to the tooltip mashup
Unfortunately, I don't have an older version extension if I found somewhere I will upload it here
/VR
Hi @Chanin
Just select the field name from the dropdown so that it will pass value from data to the tooltip mashup
/VR
Chanin13-AquamarineAuthor
Hi @Velkumar
i can select but i can't save
Hi @Chanin
What do you mean by you cannot save ? Do you see any error/information message while saving ?
From your image, I can see Google Map Properties not showing Tooltip Mashup parameters name. Save the Tooltip mashup again and reselect the tooltip mashup in Google Map widget.
If those entities (Main Mashup, ToolTip Mashup, Thing, Datashape) are not confidential, you can put them here so I can test them in my environment
/VR
