How to send Event Log files via Email
  • May 22, 2014
  • 6 replies
  • 3712 views
I would like to create a platform Expression Rule that execcutes upon file upload, and attaches the uploaded file to an email and sends it to a designated address. What is the most efficient way to implement this on the platform?
I currently have connected assets uploading event log files (.zip archives).
Thanks!
Best answer by robblack
Brenton,
Here are four examples of sending an email using the Axeda Platform: email | Axeda Developer Connection
To set up the Expression Rule for a file upload follow the instructions in File Namespace
I hope this helps. Good luck.
Rob
robblack1-VisitorAnswer
Brenton,
Rob
I was able to use the 'File' trigger type, along with If has("log", File.names) to then call a custom action and send a notification upon file upload. It appears to now be working as intended.
Brenton
How did you ensure the the Custom Object always sent the right file? Could you pass the fileId from the Expression Rule?
Alan
